Engine decarbonizing ?
Old Jun 9, 2003 | 01:09 PM
Bugster57's Avatar
Bugster57
Default Engine decarbonizing ?
Has anyone done an engine decarb proceedure on a 4 cyl.?
It's a big benefit to a carbon crusted V8 to eliminate detonation and really smooth out idle.
This is not necessary with N02 as the nitrous should take car of it for you.
Old Jun 9, 2003 | 01:23 PM
EliteAccord's Avatar
EliteAccord
Banned
Audi people uses sand.
Old Jun 9, 2003 | 01:39 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
:rofl: That's only good for port and polishing :lmao:
Old Jun 9, 2003 | 01:47 PM
Soulja's Avatar
Soulja
HAN's resident 5-0
GM actually makes stuff for this. Its available at at Chevy parts dept. Its called "upper engine cleaner"
Or, you could also pour some water in there, small amounts slowly, using a mist bottle. Disconnect intake, run engine. Open throttle plate, and spray in. The engine will bog a little bit, but the water will turn into steam with the heat and clean out the engine. With such a small amount of water, you don't have to worry about any harm.
They used to use crushed walnuts to clean bmw's. They had an attachment that connected to the spark plug hole, and blew air, and the crushed walnuts into it. Then blew the cylinder out with air. Any residual powder that was left burned off when you started the engine.
Old Jun 9, 2003 | 08:59 PM
AccordManiac's Avatar
AccordManiac
Korean Member
GM TOP Engine Cleaner or goto Napa and get some SeaFoam..
