please help with 94-97 accord
Old 06-06-2003, 09:25 AM
jem7vwh
jem7vwh's Avatar
Default please help with 94-97 accord
I've got a replacement grille molding, but I need instructions on removing the grille. I've seen other people's DIY posts where they removed the grille without taking off the bumper. How do I do this?
Old 06-06-2003, 09:53 AM
vtecaccord01
Performance isn't $$$
vtecaccord01's Avatar
are you refering to the upper grill?
Old 06-06-2003, 10:11 AM
aux
More Black on Black Crime
aux's Avatar
pop the hood and remove all the visible screws. theres one on the bottom too as well as tabs on each side.. use a screw driver to press the tabs down and pull
Old 06-06-2003, 12:22 PM
jem7vwh
jem7vwh's Avatar
yes I was referring to the upper grille
Old 06-06-2003, 01:26 PM
EliteAccord
Banned
EliteAccord's Avatar
Pop open your hood and remove the 4 philips button head screw on top.
Old 06-06-2003, 01:42 PM
b_dyche
owned by a 9 car pile-up
b_dyche's Avatar
and be gentle... it sucks when you have broken pieces to try and re-assemble...
Old 06-06-2003, 02:14 PM
jem7vwh
jem7vwh's Avatar
the screw on the bottom, is that the one near the hood latch?
Old 06-06-2003, 02:49 PM
Samson
chris is the devil
Samson's Avatar
well its easily seen... every screw that u see attatched to the grill comes off..... Its lower and in the back.
Old 06-07-2003, 08:47 AM
95AccordEXR
95AccordEXR's Avatar
5 screws, four easily seen but the on in the middle is down inside the grill. Then, using a screwdriver, press in on the plastic retainer clip on each side. pull it out.
Old 06-07-2003, 04:50 PM
accordtuner
Banned
accordtuner's Avatar
its called the "search" button. click on it.:fawk:
