car does not restart after running then starts minutes later.
Old 04-14-2011, 10:55 AM
1994 Honda Accord
1994 Honda Accord's Avatar
Default car does not restart after running then starts minutes later.
94 Accord, manual, many miles, turns on fine, then if you turn it off and try to start it again within a few minutes it will not start. It does turn over and gauges work, etc. Then starts up with no problem. Just can't turn it off and expect to turn on again right away, like at the bank teller outside driveup..always started up again after a few minutes "rest". This has been going on for years...
---------- Post added at 12:55 PM ---------- Previous post was at 12:51 PM ----------
OOps, now for the first time my gauges went wakky! Then the engine turned off and I coasted, stopped, turned it off, sat for a minute and it started back up again, is it the heat?
Old 04-25-2011, 07:17 PM
robbiebravo50
robbiebravo50's Avatar
Hey chisling67....Have had same problem with 3 out of my 4 Hondas accords. Have 90-93. the 4th one has low miles
125,000...anyhow Have U tried replacing the "Master Relay Switch" under the dash?? This has always worked for me.
Yeah it never seem to occur until it was hot day. Hope this helps
