01 Accord V6 Major maintenance tune up, need parts identified PLEASE !
I'm coming up on 180k on my 01 accord ex v6 sedan. At 90k miles I had the timing belts done with the water pump. This time I think I'll replace a few more parts listed below for safe measures. However, I don't know the part number for tension bearing and idle bearing. Please help. I'm thinking this is good enough for a major tune up, but suggestions are welcomed. Thanks guys
TIMING BELT (oem # 14400-P8A-A02)
WATER PUMP (oem #19200-P8A-A02)
ALT/A/C COMPRESSOR BELT (oem # 38920-P8C-A02)
P/S PUMP BELT (oem # 56992-P8A-A01)
CAMSHAFT OIL SEAL x2 (oem # 91213-R70-A02)
CRANK OIL SEAL (oem # 91212-P8A-A01)
TENSION BEARING ????????????????????
IDLE BEARING ???????????????????????
NGK DOUBLE PLATINUM OR IRRIDUM SPARK PLUGS x6
Parts cost (OEM) = about $250 -$300
Labor cost = $350-$400
Don't plan to DIY, since I don't have time.
