99 coupe main relay problem, help pls
My car did not start this morning, so I was trying to take the main relay out. But I was so stupid not to remove the battery cable first. When I took inside part of the relay out, some metal legs touched, I saw a spark, after that, my car still crank but not start, and my CEL was not coming on when I first turn the key to "on".
did I mess up something other than the relay?? thx (all other light in the odometer area are functioning properly, and I checked my fule pump fuse which is fine).
BTW, any one know the part number of the main relay. I found it on rockauto.com 39400S84A01, but it said "not accord 2dr". main relays for 2dr and 4dr are not interchangable????
thx alot, guys
thx alot, guys
v-card member alpha
If there is no CEL when you turn on the car, the ECU must've gotten jacked. Either that, or maybe just a fuse(s) if you're lucky, but I wouldn't get your hopes up. I'd take a look at your fuses under the hood just to be sure.
I changed my main relay. no luck...
I'm thinking about buying a used ECU on ebay, and have my mechanic put it on. is it a dealer only job??? thx a lot
UPDATE:it comes out that it's just my ACG fuse blown.... last night, I somehow missed this one....
