tranny swap (axle info)
Old 08-14-2008, 10:56 PM
Anthony Dalla
Anthony Dalla's Avatar
Default tranny swap (axle info)
Does any body know if any of the axles are differn't if you have a 95 accord with a f22B and a auto trans and you change it to a standard trans I put the standard trans that comes with the H22. And I was told there is no difference with the axles please Help.... Also does any body know what to do with the rest of the vaccum lines when you connect a cold air set up there is a vaccum line that runs down to a box underneath the stock air intake this box has filter written on it then the vaccum tube runs to another
smallbox that sits behind the right front lights.....Please help
P.S.
Thank you in advance:
:driving: :driving:
