Go Back   Honda-Acura.net > Auto Forums > Accord
Thread Tools Display Modes
Old 11-13-02, 07:46 PM   #1
svaughan
HELP!! Check Engine Code P1491 Autozone doesnt even know what this is!
Hello,
I have a 1999 Honda Accord LX 4Cyl. The CEL is coming on, reset it, came back on. Took it to AutoZone, they read off a code P1491 (Secondary Switch Solenoid Circuit Malfunction). The AutoZone guy didnt know what this was. I've tried searching on this site and the internet and cant find anything on this!? Anyone had this?
      Registered and logged-in users don't see this ad!
Register your free account today.
svaughan is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-13-02, 08:10 PM   #2
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Send a message via AIM to 98CoupeV6 Send a message via Yahoo to 98CoupeV6
Only thing that rings a bell is the VTEC solenoid. Did you give your local Honda dealer a call or go look in an auto repair manual at the library or a book store? I really have no idea
2003 San Marino Red Accord Coupe EX-V6 6MT
IMM244k miles
www.lemons300zx.blogspot.com
98CoupeV6 is offline   Reply With Quote
Old 11-13-02, 11:18 PM   #3
smokedogg
Send a message via AIM to smokedogg
try your honda dealer....they specialize in hondas so they should be able to tell you what the problem is, whereas autozones see all different makes and models every day.
smokedogg is offline   Reply With Quote
Old 11-14-02, 12:51 AM   #4
94civicEX
I got worms.
94civicEX's Avatar
Send a message via AIM to 94civicEX Send a message via MSN to 94civicEX Send a message via Yahoo to 94civicEX
If it is the VTEC solenoid, it should be around $55 from your local dealer.
99 Integra GSR
06 TSX
duck squad member #00003
94civicEX is online now   Reply With Quote
Old 11-14-02, 08:08 AM   #5
svaughan
I'm trying to avoid taking it to the dealer ($$$), that's why I posted on this board. I'm going to run the codes myself with the paperclip/reading computer LED method to see what code I get. The car is out of warranty, hence I want to save money and do it myself. Thanks for the help so far.
Old 11-14-02, 09:08 AM   #6
v4lu3s
thats an EGR code.
P1491 EGR Valve Lift Insufficient detected.
same as the OBD1 code 12
v4lu3s is offline   Reply With Quote
Old 11-14-02, 03:51 PM   #7
98CoupeV6
98CoupeV6's Avatar
Quote:
Originally posted by v4lu3s
thats an EGR code.
My EGR on my old Accord went at 60k...costed about 200 bucks all in all.
IMM244k miles
Old 11-14-02, 06:30 PM   #8
green2dr
http://mywebpages.comcast.net/jweller1/check_eng.html
Check it out and read it your self. you read the binks on the engine check light it self. After you figure out what the code is go to google.com and search for engine check codes for your car. Or just come back and post what code you got. I'll look it up for you.
green2dr is offline   Reply With Quote
Old 11-16-02, 01:14 PM   #9
svaughan
Thanks for the help guys! I ran the code myself and it flashed off a "12". So, I guess this is EGR? Does this pertain to a certain part that i can replace myself or is it the system. I really dont want to go pay big bucks at the dealer if I can change some sensor out and be fine.
Thanks
Old 11-16-02, 05:25 PM   #10
98CoupeV6
98CoupeV6's Avatar
Quote:
Thanks
The EGR is located in the headers...I'm not sure if you can replace it yourself easily, but the dealer did it very quickly. The part is the expensive thing...it retails at like 120 bucks I THINK. It may be a bit lower, I'm not sure.
IMM244k miles
Old 11-16-02, 07:16 PM   #11
v4lu3s
the egr code is thrown by either the egr lift sensor on the egr valve which is on the intake manifold, sort of between the distributor and throttle body, or the egr control solenoid which is on the vacuum tube going to the egr valve.
Old 11-16-02, 09:12 PM   #12
99accord
www.poksquid.com
99accord's Avatar
Send a message via AIM to 99accord Send a message via MSN to 99accord Send a message via Yahoo to 99accord
good to know
99accord is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
