Engine swap - Ideas?
W.I.P.
I drive a '95 accord EX-V6.
I am wondering the different possibilities with engine swaps for this model and year...
Things I know already, but have additional questions:
H22A is a popular swap, but in the 4-cyl cars. How about the V-6 models?
V-6 models have a longer nose, or so I've heard. I have never measured.
The reasons for my questions about a swap is... my engine has loud knocking coming for the valve covers. I do not have much experience with engines and engine repair, but the dealership said that it is possibly my valves; not compressing or something to that effect. ??? I have priced ordering the same engine... code C27A4, but the prices I am getting are not much cheaper than a H22, minus the install fees.
Any direction, further questions, or ideas would be greatly appreciated.
don't be discouraged, there is NOTHING wrong with your engine. you see, you have the C27A which is the same engine that was used in the 1987-1990 Acura Legend. these engines are imfamous for their lifter tick.
http://www.acura-legend.com/vbulleti...1/#post1214521
that is one solution, using auto-rx or seafoam can help reduce the lifter tick. another cure is to use lucas oil additive. best is to use both a seafoam/auto-rx and then add the lucas after you get done. I have 300k on my engine and it still ticks, but runs just as good...
as far as swapping in a 4cyl in place of the V6, you have to factor in putting in a new ECU, TCU, Trans, and a couple other small things. you need to, if you're going to swap engines, get one from japan run you about $450-500 on ebay or other places, after install about $1000.
W.I.P.
maybe it was lifter and not valve ... either way, the knock started off quiet and has progressed into something that becomes irritating... I crank my stereo to drowned it out.
I have read other posts about seafoam... what is this and what is the purpose of using it?
I have been researching the H22 swap and have quite a extensive data pile going, but the only hangup is... will it swap into the V-6 body as well as it does in the 4-cyl... according to some... one motor mount move is the only problem with being a swap for swap in the 4-cyl Accords... is this the same case for the 6-cyl?
I think first and foremost you should give it a good auto-rx treatment, or if you can't find auto-rx, settle for seafoam, available at autozone for $15 I believe. there is a 1/3:1/3:1/3 application method, crankcase, pvc, and gas tank, just do a search. then when you do the oil change right after that, add the lucas and see if that helps. if not, THEN look into an engine swap. It'll be much better to spend $25-30 to attempt to fix the problem than to spend $1000+ for an engine swap.
W.I.P.
