98 Accord Dash Lights flicker intermittently (door ajar, battery, brake lamp)
Old 03-03-2008, 02:02 PM
Deo
Deo's Avatar
Default 98 Accord Dash Lights flicker intermittently (door ajar, battery, brake lamp)
All four door ajar lights, brake lights and the battery lights come on when I rev then engine, or when I don't rev the engine at other times. I can play with the fan and they will go off as well. This happened a ways back not too long after service but has caused no obvious problems.
I have seen a few others with this generation (98-02) accord have had the same problem and made some posts on the net, but I have never seen anyone post feedback or a response of what it could be.
Anyone know the solution?
Old 03-03-2008, 03:23 PM
Misa
Pic Whore
Misa's Avatar
seems like alternator.
Old 03-06-2008, 10:06 AM
Deo
Deo's Avatar
Default 17V when running
I noticed today the battery is the normal 12.7 volts with no load but just over 17 volts with running and I believe it should be about 14.5 So if I turn on some load the dash lights go out. hummmm
Old 03-06-2008, 01:24 PM
Cousin It
Cousin It's Avatar
Alternator. It's a common problem on 6th generation V6 Accords which came with a crap Delphi alternator. Your voltage regulator is cooking off. Replace the alternator before it takes out your battery too and leaves you stranded.
Old 03-07-2008, 12:34 PM
Deo
Deo's Avatar
Thanks for the feedback!
Old 03-07-2008, 03:37 PM
Tedmond
Tedmond's Avatar
wtf 17volts? careful your car electronics ECM, PGM might be burned with that much power, better get it checked out asap also the voltage regulator is damaged or is going !
Old 03-07-2008, 06:36 PM
kerpal
kerpal's Avatar
Originally Posted by Deo
All four door ajar lights, brake lights and the battery lights come on when I rev then engine, or when I don't rev the engine at other times. I can play with the fan auto body part and they will go off as well. This happened a ways back not too long after service but has caused no obvious problems.
Probably the alternator my friend.. Dunno if having it rewinded will make it work
Old 10-22-2019, 03:17 PM
Tray Michael Kucera
Tray Michael Kucera's Avatar
Default Dont think it's the alternator
Same thing happens to me when the car downshifts (automatic) and I just changed the alternator and starter plus the battery is at 12v
Happs
Accord
5
01-24-2009 01:18 PM
bakerconch
Accord
3
08-16-2006 09:04 AM
99Accord73
Accord
06-06-2005 08:32 AM
simpson808
Accord
3
04-20-2005 01:36 PM
Al-dog
Accord
7
03-07-2005 05:02 AM
Quick Reply: 98 Accord Dash Lights flicker intermittently (door ajar, battery, brake lamp)
