H23??? Stage 2 Cams??? Help????
Old 07-19-2007, 09:10 PM
akord_king
akord_king's Avatar
Default H23??? Stage 2 Cams??? Help????
ok i did some research and is the only difference between the h22a and h23 the vtec cams on the h22a? because i was going to buy a h22a but i was going to put stage 2 cams in it but that would defeat the purpose of buying the h22a over the h23 if im going to buy stage 2 cams i would be better off getting the h23 (cheaper) and would end up with more hp then an stock h22a correct????
Old 07-19-2007, 09:44 PM
wedley2
bboy Wesley West
wedley2's Avatar
an h22 with valvetrain and good bolt ons should get you over or close to 200whp.
Old 07-28-2007, 12:09 PM
akord_king
akord_king's Avatar
the h22a comes stock with 200hp with no upgrades, bolt ons and vavltrain on an h22a should get it up to 250 or higher
Old 07-29-2007, 03:39 PM
wedley2
bboy Wesley West
wedley2's Avatar
i meant whp, 200hp stock is at the crank
Old 07-29-2007, 06:58 PM
Snoopy
been there done that
Snoopy's Avatar
you wish
yes
