Keyless entry problem - can't turn off alarm
Old 01-01-2007, 07:28 AM
ramosr2540
ramosr2540's Avatar
Default Keyless entry problem - can't turn off alarm
Hello,
The keyless entry system on my 2002 Accord is not working and I can't open the doors or start the car without setting off the alarm.
When I use the keyless transmitter the door locks won't open. I thought it was the transmitter's battery, so I tried the other transmitter and it couldn't open the door locks either.
I then opened the door with the key which set off the alarm and I tried to start the car with the key, but to no avail the ignition cutoff wouldn't let me start the car. I tried the other 2 keys that came with the car, but still no luck. Does anyone know what I can do?
Thanks...
Old 01-04-2007, 08:37 AM
sibiryk
sibiryk's Avatar
Is it a factory or aftermarket alarm system?
Old 01-04-2007, 02:22 PM
honda guy
honda guy's Avatar
sounds like gremlins
Old 01-06-2007, 01:29 PM
ramosr2540
ramosr2540's Avatar
Thank you for the reply. It's a factory installed alarm.
Old 01-06-2007, 04:32 PM
honda guy
honda guy's Avatar
So its an EX than and it has the red led by the drivers door lock knob?
Old 01-07-2007, 07:24 PM
ramosr2540
ramosr2540's Avatar
Yes, it has the red led by the driver's door lock knob.
Old 01-07-2007, 09:41 PM
stereo
stereo's Avatar
have you tryed to unlocking the passenger side door to see if it disarms the alarm? since both transmitters don't seem to work check to see if the parking lights flash like it's getting the signal. if not try reprogramming them.
Old 01-08-2007, 04:59 AM
honda guy
honda guy's Avatar
Well the only think i can come up with is the switch on the end of the lock cylinder is broken. Either from someone slim jimming the door or someone tryied to break in. When u unlock the car with the key that switch on the end of the cylinder in the drivers door dissarms the system.
Old 01-10-2007, 08:32 AM
silversport
silversport's Avatar
I had the same problem on my 99 Accord a year ago. Factory alarm. Only difference was that the key fob would sometimes unlock the passenger door but not the driver door. The car would usually start, sometimes not but it would set off the horn. The whole problem was intermittent. Turned out to be the passenger side multiplexer ($120 part, $180 to install). I think the install is pretty easy if you want to do it yourself. I can get the part # later today if you are interested.
Old 01-11-2007, 03:25 AM
ramosr2540
ramosr2540's Avatar
Sounds like my problem. Please send me part # and instructions if you have them when you get a chance. Thanks...
