1992 honda accord losing power
My 1992 honda accord is losing power if i let go of the gas it does fine then it loses power again i have to keep doing that until it works itself out or if i keep the gas pedal down to try to maintain speed it spits and sputters until the check engine light comes on them it is fine PLEASE HELP
you may have a loss in compression. there's additive for your crankcase for taht. or your fuel filter may be clogged. if you are running the stock filter maybe its time to change it.
if you don't know what additives to restore compression then you can ask the Mechanic you paid to install your #2 tranny and #2 & #3 alternator. hello.....are you still there? or is you Vtech off the (phone) hook.
lots and lots of fail
1 Post
explain to me what magical additive fixes a head gasket or piston ring for more than a couple hundred miles. band aid on a broken arm. don't even talk to me about not doing work on my car if you think half assed $15 solutions fix major engine mechanical problems.
Mom's shade tree mechanic
ecu codes
My 1992 handa accord is losing power
I got some codes from the ecu.
(1) code 14
(2)code 1,2,3,7,8
The second set of codes have a 2 second pause between each one I am not sure how to read them can anyone explain.
(1) code 14
(2)code 1,2,3,7,8
