Results 1 to 13 of 13
Thread: Intermittent ignition problem?
  1. #1
    Join Date
    Aug 2005
    Posts
    14
    Hi everyone, first time posting.
    I have a 92' accord and believe to have an ignition problem. Sometimes my car won't start.....waiting 15 min. does the trick, and fires right up. It doesn't matter if it's hot or cold, weather, etc. It only happens once every few months and I want to find the problem. I heard a common problem is the distributor. Any suggestions?
    Thanks,
    Matt
  2. #2
    Rachel Bilson <3 F22B Prelude's Avatar
    Join Date
    Oct 2005
    Location
    South Bend/Walkerton, Ind
    Posts
    11,229
    Does it crank?
    Sigs are for hoes
  3. #3
    Join Date
    Aug 2005
    Posts
    14
    Quote Originally Posted by F22B Prelude
    Does it crank?
    Yes it cranks. I did not have any tools when it wouldn't start, but I bet it wasn't getting spark. It has done this about 4-5 times over the past year....I just wait 10-15 min and it fires right up.
  4. #4
    Join Date
    Oct 2005
    Location
    Posts
    11,229
    Main Fuel Relay
    Sigs are for hoes
  5. #5
    Join Date
    Aug 2005
    Posts
    14
    Main Fuel Relay
    Thanks. I really need to do a spark test next time this problem occurs, this will determine if in fact it's electrical or fuel related.
  6. #6
    teh accord guy
    Join Date
    Nov 2005
    Posts
    193
    i have the exact same problem in my 94 ex... its not a main fuel relay. the design on the ignition components was apparently bad, because theres a few in town that do the same. i checked for spark when it wasnt starting, and there was one that wasnt sparking... you can try new dist cap, rotor, wires and plugs, but it didnt work for me, and i'm still living with the problem
    My 5th Gen Accord
    more pics on the way... finishing some mods up
  7. #7
    Join Date
    Aug 2005
    Posts
    14
    The more I am researching the problem...the more I lean towards the fuel (main) relay. My ignition system (plugs, cap, rotor, etc) is fine. I also did not smell fuel while starting it...which explains the relay not allowing the injectors to work. I also got out of the car when it wouldn't start to look under the hood. I got back in and it fired right up. The trick in that was the door slamming and knockin' the relay back to life.
    Check this out:
    http://www.alldata.com/techtips/2003/20030602c.html
    Thanks for the reply, guys.
    -Matt
    I ordered a new relay from rockauto.com for $30 shipped and will have the old one dangling under the dash until it acts up again. I will replace it with the new realy and see if that does the trick.
  8. #8
    lots and lots of fail 98CoupeV6's Avatar
    Join Date
    Dec 1999
    Location
    Deeeeeeeeeeeeeeetroit
    Posts
    23,004
    Did you do a search? There's a way to test relays to verify they work.
    2003 San Marino Red Accord Coupe EX-V6 6MT
    IMM244k miles
    www.lemons300zx.blogspot.com
  9. #9
    teh accord guy
    Join Date
    Nov 2005
    Posts
    193
    well i guess i'm gonna have to see if the relay really is the problem... so you say to give it a hit, but where is it and what does it look like?
    My 5th Gen Accord
  10. #10
    Join Date
    Aug 2005
    Posts
    14
    This is the most descriptive info. I came across:
    http://techauto.tripod.com/mainrelaydefine.htm
    I did find the info. on testing the relay with the amount of clicks in each key position. The relay has to be tested when it's not working properly. If the car runs...it's working properly.
  11. #11
    Join Date
    Aug 2005
    Posts
    14
    I replaced the faulty relay.....no more problems. $30 at rockauto.com.
    -Matt
  12. #12
    Join Date
    Feb 2005
    Location
    Northern Virginia
    Posts
    214
    Yeah, don't bother testing it as the problem is intermittent and it may test good but still be bad. For $30 just swap it out. Those things are so troublesome it's going to need one sooner or later so even if that's NOT it, you're not wasting your money. Also, although the symptoms are more prevalent when the interior of the car is hot, it can still happen at any temperature. Glad you got it fixed !!!!!
    My whips
    '79 Civic 1200 Sedan
    '87 CBR1000
    '91 Civic Si
    '07 TL Type-S
  13. #13
    Join Date
    Aug 2005
    Posts
    14
    Thanks. I made the relay accessible (dangling under the dash) for when it failed again. I had the new one in the glovebox. I wanted to be sure I was chasing the right problem.
    -Matt
  14. #13
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
