Oxygen Sensor replaced, Check Engine Light still on.
Old 12-03-2005, 06:13 PM
Scarlet L
Scarlet L's Avatar
Default Oxygen Sensor replaced, Check Engine Light still on.
My check engine light came on on my 2003 Honda Accord LX 4 cyl. a couple months ago. I took the car to Autozone and they said the oxygen sensor was showing as faulty on the reader. I bought a new sensor -- but wasn't in a hurry to put it on -- gas mileage on the highway is still between 35 and 36 mpg.
Today I replaced the oxygen sensor. I then disconnected both sides of the battery -- left them off a few seconds and reconnected them.
The check engine light went off. The next time I restarted the car the check engine light came back on.
Any thoughts? I sure would like to be able to fix this myself.
Old 12-03-2005, 06:45 PM
SumAccordGuy94
Older Honda Fanatic
SumAccordGuy94's Avatar
go back to autozone and have them reset the codes... or see if any others are comming up.
An 03 needed an O2 sensor already? how many miles on the car? it still under warranty?
Old 12-03-2005, 07:57 PM
Scarlet L
Scarlet L's Avatar
Default O2 Sensor
The car only has 47,000 miles on it -- out of warranty.
Old 12-03-2005, 08:25 PM
05CoupeLXSE
05CoupeLXSE's Avatar
Emission warrenty is much longer, have Honda fix it.
Old 12-04-2005, 07:59 AM
SumAccordGuy94
Older Honda Fanatic
i thought the warranty was 50K?
Old 12-04-2005, 12:21 PM
Scarlet L
Scarlet L's Avatar
Checked the book -- only 36 months/36,000 miles for O2 sensors. Catalytic converter has an 8 year warranty.
Old 12-04-2005, 03:22 PM
lowelcam96
lowelcam96's Avatar
Keep in mind, your car has 2 o2 sensors
Old 12-04-2005, 05:24 PM
qsd_Dan
qsd_Dan's Avatar
"I then disconnected both sides of the battery -- left them off a few seconds and reconnected them."
This method doesn't work on OBD2 equipped vehicles. You need to pull the 7.5 amp clock fuse located on the drivers side fuse panel for at least 1 minute. This will reset the computer.
Which O2 sensor did you replace, up stream or down stream? With that kind of gas mileage, I'm thinking the issue is with the down stream (cat) O2. Make sure the connections to it are good. 46,000 miles is way too early to be getting a code from either sensor.
Old 12-04-2005, 08:46 PM
SumAccordGuy94
Older Honda Fanatic
yea, make sure you changed the right sensor.. the code will tell you which sensor it is (primary [front] or secondary [rear]) and what the problem with it is.
Have the car checked again (hey, its free) and see what you turn up... then let us know what you find out.
Old 12-06-2005, 06:34 PM
stereo
stereo's Avatar
are you sure it's a faulty o2 sensor ? what code did it throw ?
