5th Gen (95) Accord door panel question
I was wondering if it was possible to disassemble the door panel for a 95 Accord. I have 2 door panels, one with a cut in the vinyl right below the window (compliments of a recent tint job) and another with a tear just above the arm rest on the lower panel (from the junkyard). Is there a way to take the top panel apart from the bottom panel and put the two good pieces together? Any ideas or comment would be helpful. Thanks!
Although the panels look like they can be separated, when taken off the door, it comes off as one peice.
But to clarify something for you. The 1995 Accord is a 5th Generation Accord (1994-1997). The 6th generation began with the year 1998 and ended with 2002
You can click this link which is for taking of door panels for a 6th gen accord. It shouldn't much of a difference wit ha 95 accord
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
