has using the lowest grade gas in your h22a caused TROUBLE?!
Old 07-28-2004, 08:33 PM
knight akkord
knight akkord's Avatar
Default has using the lowest grade gas in your h22a caused TROUBLE?!
I observed that when i put the lowest grade gasoline into my car with h22a, it chokes (car jerks as if i'm tapping on the brakes) when i drive n accelerate. is this the cause of that? or is it something else? does anyone else have this problem?... my h22a is a JDM spec. please help. Thanks.
Old 07-28-2004, 09:27 PM
Samson
chris is the devil
Samson's Avatar
i swear by 91 (highest we got).. and so do all the owners at PO.com... its made to use higher octane.. do it.
Old 07-28-2004, 10:46 PM
Nightshade
un-Touch'd krew
Nightshade's Avatar
High octane is all I can run in mine but even when the motor was in stock form I never put anything else besides 91.
Oh and don't bother with octane booster either since it will just gum up your valves.
Old 07-29-2004, 10:37 AM
Illicit Accord
Illicit Accord's Avatar
h22a is only supposed to run high octane cause it's a high compression motor...duh!
Old 07-29-2004, 12:44 PM
Bl@ck
Sinner
Bl@ck's Avatar
what you're experiencing is probably detonation.. your H22 probably = wned:
Old 07-29-2004, 06:31 PM
Mr Hyde
Accord Forum Moderator
Mr Hyde's Avatar
Are you serious??
an H22 is a high compression engine. High Octane gas isn't recommended; its required. Not using it can lead to pre-ignition/knock which can cause major engine damage.
What you are describing is knock, and its basically your engine begging you to stop abusing it.
Why spend the dough for an H22 to just save a couple of bucks at the pump. Low test will not give you the performace the engine is capable of, and it can actually cause damage.
Go to the store, buy some octane booster to bump you up to the octane level you need, then go to the gas station, and top it off with Premium gas. Then prey you didnt do any long term damage.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old 07-29-2004, 09:22 PM
knight akkord
ok ...thanks guys... oh the reason i downgraded on gas..i lost my job.. =( but now i got one again...pheeew!
Old 07-29-2004, 09:23 PM
knight akkord
what do u mean?
Old 07-29-2004, 10:32 PM
accordhybrid
accordhybrid's Avatar
Even with no job that is no reason to distroy your H22. 91 and nothing else no matter what
Old 07-29-2004, 10:33 PM
wedley2
bboy Wesley West
wedley2's Avatar
yea serious, just drive a bit less or a bit more careful.
