front camber kit LOUD CLICKING NOISE
I got a front camber kit from Ebay, and It was fine when i first put it on, then after I took it to NTB for the alignment, it has a very loud clicking noise when i brake and drive. it is very annoying and loud. i loosened the bolt that holds the control arm in the camber kit and the noise lessened. my question is, do i need to grease it or something? anyone else had this problem before??? Thanks!
You know me...
same problem here...anyone?
'91 Accord EX 2dr 5spd "Macy"
Current Mods: AEM SR Intake, Type R Shift Knob, Clears,Flat Blue Valve Cover, Polished Hose Sleeving Kit, Weapon-R Billet Throttle Rotor, Clarion ProAudio DXZ535, Neuspeed 4-point Strut Brace, Neuspeed Race Springs, KYB AGXs, SPC Extreme Camber Kit, Shaved Badges
Soon to come: Rear Disc Swap...eventually...
Originally Posted by
MrFatbooty
F you Bill Gates!
CarDomain Page
CB7Tuner Member Ride Thread
Eibach Sportlines, KYB AGXs....my front driver side is doing that. I believe my strut is blown to shit.
Even the local Honda shop could not figure out what the problem is.
My car is not a means of getting from point A to point B, it
is the point.
well like i said, i loosened the two bolts holding the "Y" shaped control upper control arms into the camber kit and it made less noise, i'm guessing that i have to lube up the bolts....is that true?
You know me...
CD7junky
I kinda doubt the strut is blown. I'm getting the same sound and I just put all of my shite on like...3 weeks ago. Everything's brand new!
MrFatbooty
F you Bill Gates!
CarDomain Page
sounds like the same thing that happened to me. the camber kit control arms arn't as fat as the stock ones, so when you put them in and start driving, the UCA will move back and forth about 1/4 of an inch. what you need to do is take out the camber kit and put bushings around them on either side to make it so they don't move around. i used washers and grease. just make sure it's tight enough, not too tight. you should be fine. if anyones got more questions lemme know or pm me or something
iLLiCit
sLammED on C5s!!!!! hell yea!!!
You know me...
Illicit Accord
Thanks for the insight!
I'm taking my car back down to the shop today. I'll ask them if that ould be a possibility!
MrFatbooty
F you Bill Gates!
CarDomain Page
You know me...
Well, that kit's on there pretty damn tight. The guy at the shop said that his best guess is that it's the bushing in there. He said I should go get some silicone lubricant and throw it on there...we shall see what happens tomorrow when I DO that!
MrFatbooty
F you Bill Gates!
CarDomain Page
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
