91 Accord idling problem
Old 11-03-2014, 04:47 PM
robbiebravo50
robbiebravo50's Avatar
Default 91 Accord idling problem
Having an idling problem at stop in Drive....wants to choke and die.
Have original 400.000 miles No check engine light, have kept car well maintained.
Idles OK in Park Plugs wires vacuum lines all good....any suggestions ?????
Old 11-04-2014, 11:54 PM
ChrisS
ChrisS's Avatar
Check and clean the ground connections: transmission, engine (valve cover), thermostat (main ground for ECU), car body, and negative battery terminal
Maybe the engine coolant temp sensor or MAP sensor.
Describe the idle
-when engine is cold
-when engine is getting close to operating temp
-when engine is at operating temp
Old 02-01-2016, 06:32 AM
cutcoils97
cutcoils97's Avatar
try cleaning iac sensor
Old 06-07-2016, 08:55 PM
daanno
daanno's Avatar
I'm with ChrisS, Coolant temp sensor. If I remember correctly, it is screwed into the thermostat housing. it's a pretty cheap part. It it fails, it sends the wrong temp reading to the ECU and the the car adjust the timing to compensate for an incorrect temp. I've swapped mine twice.
