I need help on accord 01 keyless programming
Does anyone know how to program a 2001 accord keyless remote? I just bought this used car with no remote, I got one used on Ebay. I did a search all over and could not find any instruction on how to program a 2001 accord. Please help! Thanks!
The only method I've seen is when you already have at least one remote. But here goes...
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
You could try using the lock/unlock button on the door in place of the remote, until you get to step 12 or 13. I have no idea whether that'll work...
JimBlake
'03 Accord, '07 Civic
'01 Saab 9³, '05 9²x
WEEEEE!!!!!
eh.. you want to make sure your car has the keyless remote entry option on it first.... Sounds kinda stupid, but doesn't hurt to make sure ya know.
"P: Noise coming from under instrument panel. Sounds like a midget
pounding on something with a hammer.
S: Took hammer away from midget."
My toddler screwed up my remote by pushing the buttons a bunch of times today. Seemes harmless, but when i went out to the car afterwards the lock/unlock/trunk buttons wouldnt work. Can I reset my existing remote with this procedure-without buying a replacement one first?
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
