electrical issues in 2005 Accord, random or correlated?
Old 01-18-2013, 08:08 AM
Abita
Abita's Avatar
Default electrical issues in 2005 Accord, random or correlated?
2005 Accord Coupe
window control on drivers side intermitantly goes out, then passengers side window starts doing same thing and drivers side started working fine. Passenger window went down all by itself without buttons being pushed. Radio makes loud popping noise then goes out, comes back on, goes back out. Check Fuel Cap light come on, although cap IS on tight, goes off when i push odometer button, but comes back on next time car is started. dash lights flashed on when door is opened but key is not in ignition (only happened once). I checked the ground wire coming from the battery, it is not corroded or loose. any other suggestions? is this just random things happening or are they all tied together? is the car going to blow up?
