Go Back   Honda-Acura.net > Auto Forums > '92+ Civic/EL & Del Sol
Thread Tools Display Modes
Old 07-18-02, 12:27 PM   #1
str8edgexx
str8edgexx's Avatar
Allen Key Bolt???
I just received my '99 Si rear sway bar, and I had a question. On the end links, there is the nut at the end, but then there is also a place for an allen key on the actual bolt. What is this for? What does it adjust? How do I adjust it? How much do I adjust it? Thanks in advance.
      Registered and logged-in users don't see this ad!
Register your free account today.
str8edgexx is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-18-02, 12:46 PM   #2
Fujiwara Takumi
It's my first day.
Fujiwara Takumi's Avatar
Send a message via AIM to Fujiwara Takumi Send a message via Yahoo to Fujiwara Takumi
Re: Allen Key Bolt???
Quote:
sounds like youd be inserting an allen wrench in there in order to hold the bar while you adjusted the end links by spinning them up or down. similar to your struts only this provides adjustability?
www.isellmiataparts.com - World Champion Miata Parts Sales.
Fujiwara Takumi is offline   Reply With Quote
Old 07-18-02, 03:00 PM   #3
str8edgexx
str8edgexx's Avatar
I'm not sure....anyone who has put on one of these bars know?
Old 07-18-02, 03:57 PM   #4
purplx
purplx's Avatar
what fujiwara said
purplx is offline   Reply With Quote
Old 07-18-02, 04:02 PM   #5
Fujiwara Takumi
It's my first day.
Quote:
Originally posted by purplx
what fujiwara said
someone agreed with me...
Old 07-18-02, 04:32 PM   #6
str8edgexx
str8edgexx's Avatar
ok, so what exactly would turning the allen wrench adjust? I appologize in advance for the newbie-ish questions.
Old 07-18-02, 06:49 PM   #7
purplx
purplx's Avatar
on one end you have the allen key hole. on the opposite end or behind that you should have a nut. use an open end wrench or socket to tighten or loosen the nut and the use the allen key to keep the bolt from spinning while you're tightening or loosening it.
Old 07-18-02, 06:56 PM   #8
Fujiwara Takumi
It's my first day.
thanks lucy, im too tired to 'splain anymore.
Old 07-18-02, 07:51 PM   #9
purplx
purplx's Avatar
you're welcome ricky.
Old 07-18-02, 08:30 PM   #10
str8edgexx
str8edgexx's Avatar
ok...I got you...thanks. So that doesn't really adjust anything...now it all makes sense. Thanks a lot guys
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
