powersteering?
Old 06-05-2003, 06:33 PM
EBPSI
EBPSI's Avatar
Default powersteering?
I hear that not having your powersteering hooked up adds some good horse? True? If so, if I just take out the power steering fuse, will that do the trick or will that screw anything up? But how much of a difference will it make?
Old 06-05-2003, 08:13 PM
maestro5050
maestro5050's Avatar
Welcome to the boards EBPSI. There are threads discussing this topic already. PLEASE use the search tool in the future prior to posting a new topic.
To answer your question, taking the fuse out will do nothing. You would need to take the belt off the pulleys at the very minimum. Doing so will not really add horse power, but will allow more horse power from the engine to make it to the wheels since there is one less component to turn. Also removing all the power steering components will help with weight reduction.
Old 06-06-2003, 06:10 AM
fish
fish's Avatar
It's called parasitic loss, much like a supercharger. As stated before it's not going to work by simply removing the fuse, you need to at minimum pull the belt or completely remove the system (pump, belt, and the rack). It's about a 50 pound difference if you remove everything, not including the horsepower that is freed up from the crank.
Old 06-06-2003, 08:20 AM
Josh M
Josh M's Avatar
Its not going to gain you that much power......although I don't miss it very much in my accord I do notice it when parrall parking or turning into an equally difficult tight spot....I'd leave it in......
Old 06-06-2003, 09:53 AM
Tirod
Tirod's Avatar
hp wise i dont believe it effects in a straight line and not using the pump...
Old 06-06-2003, 04:50 PM
Realm730
Realm730's Avatar
My friend removed the power steering belt on his 99' si and it added 5 whp on the dyno
Old 06-09-2003, 07:00 AM
pinoyboy
im asian
pinoyboy's Avatar
isnt pwrsteering on the same belt as ac?
Old 06-10-2003, 10:01 AM
spooncivicb16b
spooncivicb16b's Avatar
i don't think it's worth it.not if its your everyday driver.
Old 06-20-2003, 10:28 PM
likaciv
Pretty Much its a Civic
likaciv's Avatar
since i put my new motor in i havent had the chance to look into a pump for the b18c. It kinda blows with now ps when your trying to parallel park as stated before. I also noticed when im taking hard corners and such the car feels much more confident in the turn with the ps.
Old 06-21-2003, 08:52 PM
Redcivic
One of the original OG's
Redcivic's Avatar
I did it for while because I was lazy after my swap and hated it. Oh, and there are pretty much no gains from removing it. I thought my car felt squirrley (sic) without it. I would'nt bother. The weight saving would be nice if you had a race car.
