d15b7 w/z6 head
Old 06-02-2003, 06:41 AM
saxtonpaxton
crvtec beast
saxtonpaxton's Avatar
Default d15b7 w/z6 head
I have a 94 DX hatch and i am about to purchase a z6 head that i would like to swap on there. Its comming with the cover, distributor, vtec solenoid, and cam gear. What else do i need to complete this swap? Do i have to change the ecu? intake manifold? what headgasket should i use?
Most of all the information i have found is swapping it onto a 4g civic. Can someone point me to some resources for this mini me swap
Old 06-02-2003, 07:03 AM
Motohip
Motohip's Avatar
You deffinitely need the ECU from the Z6 otherwise the VTEC won't work. You don't need anything else as far as I know, but it would be a good idea to get the intake manifold and throttle body for more horsepower. You can also get the tranny for shorter gearing.
Anyone else think of something else he might need?
Oh and you can get a head gasket for a 96-00 Civic EX (D16Y8) cause it's thinner and will bump the compression up a bit. Or you can get aftermarket.
Old 06-02-2003, 12:33 PM
ManTiS
NinJA
ManTiS's Avatar
You don't necessarily need the ECU. You can run a rpm switch but then you wont have the correct ign/fuel maps and your redline will be same.
Old 06-02-2003, 02:22 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
get the p28 ecu (for the z6). It's just a lot less hassle. The chassis is already wired for vtec, so you just need to run a couple wires from the vtec solenoid to the wiring harness. The z6 manifold will flow a lot better, but the throttle bodies are the same diameter. Use the b7 TB and the z6 manifold. Then you don't have to worry about moving the MAP sensor to the tb (where it is located on the z6).
The z6 head gasket has been discontinued and is now the same as the y8. It'll give you SLIGHTLY higher compression. You can also use the b7 yhead gasket if you like. Basically, whatever is cheaper. The difference is MINIMAL at best. Also, the exhaust manifold on the z6 flows a lot better, so if you don't have an aftermarket header yet, use the z6 one, or buy a header.
Old 06-02-2003, 02:37 PM
Motohip
Motohip's Avatar
Plus you need the cat from a Z6 or an aftermarket one if you use the Z6 header since your cat is stuck to the header.
Old 06-02-2003, 05:27 PM
ManTiS
NinJA
ManTiS's Avatar
My B7 has an undercar cat. A Y8 exhaust manifold was strictly bolt-on.
Old 06-02-2003, 07:06 PM
Motohip
Motohip's Avatar
So did my B7, but that's cause it was an LX. All 5th gen LX, EX, SI has an undercar cat. Just the DX doesn't. Don't know about VX and CX though.
Old 06-02-2003, 07:54 PM
saxtonpaxton
crvtec beast
i think my dx has an undercar cat...
Old 06-02-2003, 08:58 PM
Motohip
Motohip's Avatar
Trust me, it doesn't.
Old 06-02-2003, 10:30 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
My del sol S had the b7 in it, same as the civic dx, and my sol, like all civic dx's I've seen had it exactly where the Si's had it. The cx has it right off the header.
