Constant grind of 2nd
Old 05-31-2003, 07:47 PM
TypeRCivicEG6
I'm confused
TypeRCivicEG6's Avatar
Default Constant grind of 2nd
Everytime i go to shift into 2nd that SOB grinds (when driving normal and racing). Could it have anything to do with my short shifter or clutch or tranny?
Old 05-31-2003, 09:42 PM
maestro5050
maestro5050's Avatar
Could be anything. When you installed the short shifter, did you replace the bushings underneath the car with aftermarket ones? If not I would start with that first. I know the Neuspeed ones are made from polyurethane and should only run you $10-20 bucks max. They make a big difference in shifting, especially if the old OEM bushings are damaged or warped.
Old 05-31-2003, 10:06 PM
WideBodyEK
Stage 3 Modified
WideBodyEK's Avatar
short wouldnt cause it to grind,....there could be 2 things wrong with your car,....either you need some tranny fluid,....or your 2nd gear syncro is done,....you can try to flush and fill the tranny (with Honda MTF) but im thinking its your 2nd gear syncro that is bad
Old 05-31-2003, 11:32 PM
93si
93si's Avatar
sounds like a syncrho to me, my 3rd gear sync is dead
Old 06-01-2003, 06:08 AM
96extec
96extec's Avatar
car you replace the syncro's or do you have to goet a new tranny?
Old 06-01-2003, 09:03 PM
WideBodyEK
Stage 3 Modified
WideBodyEK's Avatar
well you can replace the syncros but most of the time it would be cheaper to find another tranny,...alot of tranny shops will try to dick you around saying shit like,.."oh well your soand so syncro is going out too so you will need to replace that" and even if you have them check it out to see if it is your syncro your still paying some money for bench time,...which is them taking your tranny out and then opening it up,...and then putting it back together and back in the car
