VTEC problem
Old 05-03-2003, 09:14 AM
mrbrider
mrbrider's Avatar
Default VTEC problem
I am helping co-worker with VTEC problem on 93 Civic. This engine he just put in and is a double overhead cam engine with VTEC. He says engine comes in 95 Del Sol but he got from Japan with computer and all. The VTEC comes in early at 3500 rpm and causes engine to load up or bog down. After 5000 rpm it clears up. We checked the solenoid and it is being turn on at that rpm by the computer, and should not come on till higher rpm from what we know. We have not found info to tell us what the computer is using to turn this on. Also his rev limiter is coming on to soon for this engine. Does anyone have more info on the system and what parameters the computer is looking at and so on. We have only found trouble code repairs for VETC on solenoid and oil switch but not on if system is not on right rpm. We tried Mitchell and All Data manuals on linebut no help. We are thinking he may have gotten wrong computer. The original computer for car does the same thing and it had VTEC
Ray
Old 05-03-2003, 09:32 AM
Paul
Eater of Rice
Paul's Avatar
Default Re: VTEC problem
Ray
What does the sticker on the ECU (Computer) say on it?
There will be a series of numbers:
XXXXX-PXX-XXX
I need to know which digits those are.
Old 05-03-2003, 10:24 AM
Motohip
Motohip's Avatar
I hate it when people post crap and never check back. Here is a good example of a guy that wants to help, but the tard loses his chance.
Old 05-03-2003, 11:40 AM
NeverBX
Snootchie Bootchies!!
NeverBX's Avatar
if its an OBD1 im guessing the guy who had it before might have thrown in a crap programmed chip with his wants but not your needs. i dunno.
Old 05-03-2003, 06:06 PM
mrbrider
mrbrider's Avatar
Default Re: Re: VTEC problem
XXXXX-PXX-XXX
I will get those numbers Monday and get back to you.
Old 05-03-2003, 06:15 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
He posted this today... wtf are you talking about? :eh:
Also, look at the block and see what engine it is for sure. Sounds like a B16A, but it would help to know for sure so that we know if you're using the right ECU.
Good luck man.
Old 05-03-2003, 09:36 PM
mrbrider
mrbrider's Avatar
XXXXX-PXX-XXX
I managed to get in touch with the owner and got the numbers off the computer. They are 37820-P07-000
Ray
Old 05-03-2003, 09:41 PM
mrbrider
mrbrider's Avatar
Good luck man.
It is a B16A2 , Thanks
Old 05-03-2003, 10:47 PM
Motohip
Motohip's Avatar
Good luck man.
:doh: My bad.
Old 05-03-2003, 10:49 PM
dantastic
cx power!
dantastic's Avatar
Location: berkeley, ca --> la, ca representin' tha 510&626
p07 = wrong engine computer. you need a p30 or a chipped p28. more info here: www.hondata.com
