blox lower control arm common issue?
sup guys,
any of you guys bought blox lca for civic or intergra?
did you notice that maybe a week or 2 after the install, there were cracks that formed around the bushings that it looks like the bushing and the metal insert is about to come apart???
just asking maybe its just my car or maybe its a common failure to blox lca.
The blox lca are fancy oem replacements that uses rubber bushings that are prone to cracking. For a fraction of the cost, a set of oem lcs w es bushings would better then blox. I used to run F7 lcas, no rubber bushings, poly bushings w metal inserts and adjustable holes for sway bars.
