2004 Acura EL
Old 08-04-2010, 08:42 AM
Tark
Tark's Avatar
Default 2004 Acura EL
What should i check for before buying it?
Old 08-04-2010, 05:14 PM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
All the typical things for an 02-05 Civic Sedan.
Timing belt (even if the car you're interested isn't at 100K miles, you're due based on time).
Evidence of routine oil, transmission fluid and coolant changes.
Decent alternator output.
No rust; clean drain bungs.
No hidden accident damage.
Etc.
Old 08-05-2010, 07:32 AM
Tark
Tark's Avatar
thanks!
Old 08-26-2010, 01:14 PM
IanB
MB4
IanB's Avatar
Also listen for noisy suspension on your test drive, the 7th gen civics/EL's had bad luck for struts failing, otherwise a great car! If you buy, check out clubel.com as well.
