2002 civic main relay location "help" irratic tach/idle
i have a 2002 civic LX auto,cant find the main relay?car starts and runs,i can hear the fuel pump relay clicking and the tack goes up and drops with the click,then relay stops clicking(behind the glove box) and the tach goes to 0 still running but doesnt rev up without bucking a bit and boggs any ideas
the only relay i found under driverside dash was for the auto cruise
so you cant find the main relay, even though you heard it clicking behind the glove box?
Yes, Its back behind the glove box, right where you heard it. you can release the glove box so it opens wider, then remove the panel thats to the right of the glove box and you'll see it.
2002 Honda Civi main relay
I had the same problem with my 2002 Honda Civic EX. During the day, it would get hot and stall out while driving. Here is a pic of the relays with part numbers and where to buy them. Hope this helps anyone else with this problem.
Identical Problem - Relays Click - No Power
I have a 2004 Civic that is having the same problem you described. Can you tell me what you found was causing the problem?
I've looked everywhere until I found your post, I hope you have the answer!
