Go Back   Honda-Acura.net > Auto Forums > '92+ Civic/EL & Del Sol
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 11-03-09, 11:21 AM   #1
90CvcDX
kekeke
90CvcDX's Avatar
Going boost, have question about clutch choices.
I searched but found nothing relevant to what I'm looking for.
So I've finally given in and decided to boost the d16 in my EJ7. The thing is the turbo isn't in yet and I can already feel the clutch slipping. The motor/tranny has about 171k miles on it but it runs great... except the clutch Now I'm a newb when it comes to working on the guts of a motor or transmission so I've never replaced a clutch myself. The motor specs are 115HP/104TQ factory and with the 6lbs of boost I plan to add i don't expect a HUGE gain in either/or. So I ask which type of clutch should i be looking for? I posted a link to an Exedy cerametallic clutch kit i found while browsing around along with the specs on the turbo itself if that'll help at all. Let me know if this is what i should be looking to get or if it's too much/less. Thanks in advance.
http://www.prostreetonline.com/pnsku/08902a.asp
Turbo specs:
.50 Compressor A/R
.63 Turbine A/R
3.0” Inlet / 2.0” Outlet
Oil Cooled Shaft & Internals
Compressor Wheel
0.50 A/R Cold Side
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Turbine Wheel
0.58 5-Bolt Standard Hot Side
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
      Registered and logged-in users don't see this ad!
Register your free account today.
90CvcDX is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
