Go Back   Honda-Acura.net > Auto Forums > '92+ Civic/EL & Del Sol
Thread Tools Display Modes
Old 08-30-09, 05:18 PM   #1
CRiSS
honda confusion...
a friend of mine has a 99 civic vp 1.6,and it will start right up,only after he lets it sit for about 15-20 min...if he jumps out and right back in it will just keep crainking, it will not start, so i thought it might be the fuel filter, because he has 105,000 mi and has never changed hit filter..but he still has the problem...im a legend man myself i have never touched a 99 civic ...any ideas????
      Registered and logged-in users don't see this ad!
Register your free account today.
CRiSS is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-31-09, 02:50 AM   #2
Shameinator
what does the cranking sound like? It could be a bad dizzy. I had this problem when my head gasket was blown but thats a little extreme right now.
Shameinator is offline   Reply With Quote
Old 08-31-09, 07:39 PM   #3
A-TownCivic
pull an ejector out and crank the engine to see if it's getting fuel from the pump once it's hot. Sometimes when a fuel pump is going bad it starts out by failing to start when it's hot.
Distributor? Fouled plugs?
A-TownCivic is offline   Reply With Quote
Old 09-02-09, 04:04 PM   #4
cruzalekz
change main relay,, overheats i believe (main relay) fires right up when cold right? if yes, well u know what i suggest
cruzalekz is offline   Reply With Quote
Old 09-10-09, 07:36 PM   #5
CRiSS
i changed the plugs ,wires ,and fuel filter,and the car ran great..with no starting isues for about 4 days,,,now she wont start AT ALL...i m looking into the fuel pump ..only because i cant hear it when i go to acc....i will check the injecters,and main relay....
Old 10-11-09, 03:35 AM   #6
speedy888
speedy888's Avatar
change the PGM-Fi relay
speedy888 is offline   Reply With Quote
Old 10-11-09, 03:39 AM   #7
car2n
Yes main relay needs to be re-solder or replaced.
car2n is offline   Reply With Quote
Old 10-30-09, 02:57 AM   #8
ohdav3y
del slow
yup main relay, just helping add to the repsonses
ohdav3y is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
