Where is the radiator fan switch? or what ever makes it engage
Old 06-15-2009, 04:09 PM
ReVenGe
ReVenGe's Avatar
Default Where is the radiator fan switch? or what ever makes it engage
(94 cx with d16z6 motor)
Cars overheating from radiator fan not turning on. Fan is functional (connected to 12v source and it turns on)
I know i had an aftermarket fan switch installed a long ass time ago... to make it turn on at a lower temperature..
anyone have any diagrams where to start looking?
Old 06-16-2009, 09:52 AM
ReVenGe
ReVenGe's Avatar
bah.. no one has a quick diagram on hand?
found. it.. on thermostat :doh:
Old 06-18-2009, 06:26 AM
Running925
Your Powder Coater
Running925's Avatar
yep, on thermo housing.
and if you pull the plug off and loop the two wires together with a short bare jumper wire or a paperclip as a test. It should kick the fan on if the key is in the on position. This will usually show you if your sensor is bad or not.
Old 06-18-2009, 04:10 PM
06gsxrman1000
06gsxrman1000's Avatar
if that doesnt work the relay is under the hood on the right hand side or left lol depending on which way you look at. Either way its on the pass side
Old 06-20-2009, 12:13 AM
A-series
v-card member alpha
A-series's Avatar
That sensor/switch is called the thermoswitch, just makes it easier to use that term if you end up looking for a replacement or search for info on it.
Old 06-20-2009, 08:35 AM
cruzalekz
cruzalekz's Avatar
ect input makes the fan engage which is basically grounded by the pcm at a certain temp
Old 06-20-2009, 11:45 PM
fgodmaire
fgodmaire's Avatar
i did this way .... manuel switch ...
i wasnt finding the problem ...
i make an habit now lol....
at the 2 wires plug near the fan...
Old 06-22-2009, 01:15 AM
A-series
v-card member alpha
A-series's Avatar
On that engine there's a separate sensor to relay temp. to the ECU (ECT, in head below distributor) and another switch just to kick the fan on, the thermoswitch.
