What to add to my suspension setup?
Old 06-18-2002, 09:51 PM
MyStyle00
MyStyle00's Avatar
Default What to add to my suspension setup?
I am just wanting to make my car A LOT of fun on back roads, to where I can out-handle the competion. I want to also run a little auto-cross here and there. All this on a low budget by the way.
I have FRONT and REAR UPPER strut bars already. I want to know if I should buy BOTH lower front and rears? I heard at one time that it's not good to run all 4.
Then I started to think about a sway bar. Which is the most effective for the least amount of money...and no major modifications to put on. Would a GSR's bolt STRAIGHT up?
Please let me know. Thanks!
MyStyle00@aol.com
Old 06-18-2002, 11:09 PM
agent87
Need zzzzz's
agent87's Avatar
If bang for the buck is important to you, I think you should go with a rear swaybar. I'm assuming you have a '00 civic. If so, getting an aftermarket kit like Suspension Techniques might be easiest. Your other options would be to go for the SI sway bars and mounting equipment (do non-SI's have mounting holes in the LCA's?) or the ITR bar, required equipment, and a Beaks kit (be warned that you might want to have a bar up front as well.) I'm not sure if a GSR's will bolt straight up.
EDIT: About strut bars: I'm all for stiffening the chassis as much as possible but many times it's hardly noticeable and doesn't follow the budget route.
Old 06-18-2002, 11:54 PM
ManTiS
NinJA
ManTiS's Avatar
Strut bars should come last. Get stiff springs and adjustable dampers. I love my 450f/550r springs ... they feel sooooo good
Old 06-19-2002, 02:32 AM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
Actually if you are going to autocross don't do anything to your car. Mods will bump you into more difficult classes. If you don't care and just want to do it for fun than I would suggest coilovers and Koni Yellows. I'm using custom rate Ground Controls with Koni Yellows and it's sweet. You just have to make sure you get all sides the same height. I have mine within 1mm of each other.
Autocross Help Page
Old 06-19-2002, 05:28 PM
FourthGenHatch
I'm RICK JAMES, bitch!
FourthGenHatch's Avatar
I got front and rear strut bars and it DOES make a noticable difference in steering, but then again I have no power steering.
Old 06-19-2002, 06:28 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
ya damn straight! cars with PS it's almost no difference. non PS it;s awesome.
Get some nice springs/coilovers and some good shocks. Then worry about sway bars. Then bushings.
Old 06-19-2002, 09:00 PM
MyStyle00
MyStyle00's Avatar
Well I already have GC's w/ KYB AGX's lowered approx. 2"...AND I also dont have any PS...AND I already have both front and rear uppers...So I am asking what else, such as both or only one lower strut bar and/or a anti-sway bar.
Old 06-19-2002, 10:23 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
tie bar, bushings, and swap bars.
Old 06-20-2002, 02:42 AM
CivicSiRacer
For the typical daily driver you will not see a difference. For autocrossing you might/might not. It's not one of the HOLY COW! mods. For road/track days you will see a different since the speeds are much higher.
Autocross Help Page
jH4nd
Accord
2
06-03-2008 05:28 PM
evolution
S2000
9
06-15-2006 03:01 AM
rvfrick
CL, TL, TLX & Vigor
2
12-13-2003 11:58 PM
civicburner
92+ Civic/EL & Del Sol
3
09-08-2003 08:03 PM
KrazyPRican
Accord
3
01-13-2003 04:16 AM
Quick Reply: What to add to my suspension setup?
