del Sol GS-R swap motor mount help
Old Jan 25, 2009 | 09:33 AM
3xternal's Avatar
3xternal
Default del Sol GS-R swap motor mount help
I have a 94 del sol VTEC with an Acura Integra GS-R swap on Hasport mounts.
It rattles like all hell. I want to install OEM mounts (softer) to minimize some of the vibration.
What OEM mounts do I get? Integra or del Sol? Be specific for each mount (transmission mount, rear mount, side mount, right front mount, and left front mount.)
2nd: The left front mount is based on an air conditioning bracket. The guy who did the swap tore out the AC and the bracket went with. On another forum I read that bracket and the mount that goes with it make an excellent tortion mount, which I really need.
What AC bracket do I get: Integra or del Sol?
What engine mount do I get (OEM) for that bracket?
I only know what I have read on other forums. If I am terribly wrong on anything here, please inform me and point me in the right direction.
Old Jan 25, 2009 | 12:39 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Get the GSR stock mounts. As for the Ac mount you can use either the GSR or the Delsol. If you are trying to put AC back in then you have to use the Delsol one.
Old Jan 25, 2009 | 12:50 PM
3xternal's Avatar
3xternal
This is what I was afraid of. I posted on multiple forums to get the best answer. The other guy is saying use the Del Sol VTEC mounts.
http://hondaswap.com/hybrid-eg-ek-dc...7/#post1225582
Old Jan 26, 2009 | 06:48 AM
HatchVX's Avatar
HatchVX
You could use the delsol VTEC mount too, you have to make sure the left upper mount is the same. They have a 2 hole and 3 hole config. The others should bolt right up.
Old Jan 26, 2009 | 02:26 PM
Civic2Scooby's Avatar
Civic2Scooby
you can use either the GSR mounts or the Del Sol VTEC (b16a3) mounts. As said above just make sure you get the proper 2/3 bolt mount.
Old Jan 30, 2009 | 02:35 PM
thetunersource's Avatar
thetunersource
Or you can just use the mounts on the motor itself. The Del Sol uses the same mounts and it should work perfectly.
