question...
Old 12-07-2002, 02:15 PM
94 UnKnOwNCiViC
94 UnKnOwNCiViC's Avatar
Default question...
would a 2002 D17A2 civic ex motor fit in my 94 civic ex?..jus wondering..cause my motor is going bad...thanx
Old 12-07-2002, 02:54 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
It won't bolt in directly. You;d have to do some custom fabrication to get it to work Frankly, there are a lot of other engines that will drop in relatively painlessly. You can drop in pretty much any B series engine without much grief. My choice would be a B18C1 with a B18B crank and B18B rods.
Old 12-07-2002, 02:57 PM
whiteEJ8
whiteEJ8's Avatar
Would the longer stroke lower the redline?
Old 12-07-2002, 05:32 PM
94 UnKnOwNCiViC
coo..thanx.
Old 12-07-2002, 05:36 PM
EX R8ED
is whipped
EX R8ED's Avatar
Yeah, I'm curious as to why you'd choose to do this as well. By all means, fill me in.
Old 12-07-2002, 08:44 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
No. Redline is not governed by the crank. The longer stroke would in essence give you an LS/VTEC without the (un)reliability issues. It's easier to swap an LS crank and rods into a GSR block than it is to put VTEC oil squirters, oil pump, water pump, and block girdle into an LS block. You would have all the benefits of an LS/VTEC without the problems.
Old 12-07-2002, 09:48 PM
EX R8ED
is whipped
EX R8ED's Avatar
Could you expand on this. Explain what happens when you put the LS crank and rods in.
Old 12-07-2002, 10:35 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
The LS crank has a longer stroke. That's why an LS displaces more than a GSR. That's also why an LS has more low-end torque than a GSR. When you slap a VTEC head on an LS block, you get the LS stroke and low-end torque, as well as the VTEC pull in the upper RPM range. Building an LS/VTEC properly can be a bit costly, unless you're good at machine work. Most people just slap a VTEC head on and call it a day. This can lead to many problems, one of which is improper oiling. By putting an LS crank and rods into a GSR block, you get the benefits of an LS/VTEC plus you already have the pre-existing VTEC oiling components, as well as an OEM block girdle.
Old 12-07-2002, 10:40 PM
94civicEX
I got worms.
94civicEX's Avatar
Damn Chris, that's a wicked good idea. I don't know why you don't see more people out there doing it.
99 Integra GSR
06 TSX
duck squad member #00003
Old 12-07-2002, 10:52 PM
EX R8ED
is whipped
EX R8ED's Avatar
Thats what I was thinking...:dunno:
