does 99 rear sway bar fit on a 98 civic ex
Old 12-06-2002, 09:37 PM
jordan88
jordan88's Avatar
Default does 99 rear sway bar fit on a 98 civic ex
i have a 98 civic ex coupe, i am just wondering would a 99 civic si rear sway bar fit on a 98 civic ex coupe?
thanks you!!
Old 12-06-2002, 11:18 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
Yes. You need the bar, D-brackets, bracket mounts, bushings, and endlinks. The OEM Si bar is pretty tiny(13mm), so you may want to go with an aftermarket or ITR bar.
Old 12-07-2002, 10:06 AM
str8edgexx
str8edgexx's Avatar
I have a swaybar from a '99 Si on my '98 Lx, so yes it works. According to Honda's website, they say the rear swaybar on the '99 Si is 15mm, while the one on the '00 is 13mm....
Old 12-07-2002, 10:10 AM
Paulll
Hail Bent
Paulll's Avatar
it should, i dont see why it wouldnt
Old 12-07-2002, 01:21 PM
jordan88
jordan88's Avatar
do i need to drill any holes or any modifications?
Old 12-07-2002, 01:23 PM
str8edgexx
str8edgexx's Avatar
nope....the holes are all there....if you can put a bolt through a hole and put a tighen a nut on the other side, you can do it...takes maybe an hour...maybe
