Results 1 to 17 of 17
Thread: things to note when installing a turbo...
  1. #1
    ghey slow d16 modder
    Join Date
    May 2002
    Location
    fairfax, va
    Posts
    450
    i'm getting an apex kit for my 97 ex. i'm deciding how serious this job is and what to expect out of it. i'd rather not get into it over my head, and i'd like to not hit anything unexpected. anyone have any advice? how hard is it to do the job? i'm pretty handy with cars, but never done something so big. i figure it's mostly bolt-on, right???
    like i said...any advice would be great. thanks.
    dave
    SOHC: 284whp/250tq @ 14psi (with dx tranny)
    www.capitolraceway.com
    www.mirdrag.com
  2. #2
    been there done that Snoopy's Avatar
    Join Date
    Jun 2002
    Location
    916
    Posts
    30,607
    probably the hardest part would be welding the oil drain hole to the oil pan. and maybe some wiring if you have to do that sort of thing. just take your time, double check all your connections, and pick up a helms manuel.
    this is my signature. there are many like it but this one is mine.
  3. #3
    のんびり~(´ε`) inspyral's Avatar
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    It's basically an intake/header install, with the added components of running the oil lines, vac connections, installing feed/drain fittings, plumbing fuel connections, etc. The A'PEXi kit uses a gasket-sealed fitting and bolts for the drain fitting int he pan like the GReddy kit, I believe, so you won't need to weld it. For a first time install, it should probably take a full weekend. Make sure you double check all your connections. Isolating a leak is a pain once you have everything back together. You'll need an assortment of tools, obviously. Post any specific questions if you have them.
    peace an' luv-
  4. #4
    Spec5
    Join Date
    May 2002
    Location
    Northern VA
    Posts
    1,353
    Originally posted by inspyral
    ...uses a gasket-sealed fitting and bolts for the drain fitting int he pan ...
    so does this mean you basically just drill a hole or something? how does this work... just curious
    '06 Whitewater Pearl Mazdaspeed6 --> current!
    '02 Blackout SE-R Spec V --> 1/04-8/06
    '93 Torino Red Civic 4dr --> 9/99-1/04
  5. #5
    NinJA
    Join Date
    May 2002
    Location
    WISCONSIN
    Posts
    1,707
    yes, drill the hole and tighten nuts
    Senpai
    Contents:
    D16A6 / D16Y8 mini me
    Removing Transmission
    Installing Clutch
  6. #6
    Join Date
    May 2002
    Location
    fairfax, va
    Posts
    450
    does this kit come with good instructions??
    www.mirdrag.com
  7. #7
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    Are you getting it new? I believe it comes with pretty detailed instructions. This should help:
    http://www.wabe.net/silum/turbo.html
    pretty pictures, too.
    peace an' luv-
  8. #8
    Join Date
    May 2002
    Location
    fairfax, va
    Posts
    450
    thanks, that site will be really helpful. one more question...is turbo magazines website usually a reliable source of info?? they said that the apexi kit with the gt intercooler at only 5lbs of boost makes 187whp...i'm not sure how accurate that is, since i know kits like greddy only give a sohc like 140whp. check out this site:
    http://www.turbomagazine.com/tech/0108tur_apexturbo/
    www.mirdrag.com
  9. #9
    I got worms. 94civicEX's Avatar
    Join Date
    Jul 2000
    Location
    Utah
    Posts
    31,818
    Damn, that's an awesome How-To. That looks really nice.
    Good luck, bro', maybe take some pictures as well.
    99 Integra GSR
    06 TSX
    duck squad member #00003
  10. #10
    NinJA
    Join Date
    May 2002
    Location
    WISCONSIN
    Posts
    1,707
    Instructions with the Apexi kit are really good (for me anyways.)
    Senpai
    Contents:
    Installing Clutch
  11. #11
    S2000 Pilot Jkan2001's Avatar
    Join Date
    Jun 2002
    Location
    9000 RPMS
    Posts
    2,457
    make sure you teflon tape the threads for the oil feed....i have the APEX kit on my 00ex and the guy that had the kit before me forgot to teflon tape it. I didn't think to even check it and after i installed the whole kit i started it up and it LEAKED OIL so i had to take it all off and basically reinstall the whole kit.
    -2000 Grand Prix White S2000-The daily driver
    -2006 Canyon Red Lotus Elise- The weekend Toy
    -2009 Pepper White Cooper S- The grocery hauler
  12. #12
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    They tuned the A'PEXi kit with an AFC. The numbers you're thinking of for the GReddy kit are probably untuned. The GReddy kit is also a good option for SOHC boost, but it may take more boost pressure to make the same power. You can easilly get past the 200hp mark with a GReddy kit, but t will take some good tuning with a standalone unit, and at about 8-12lbs of boost to do it.
    peace an' luv-
  13. #13
    Spec5
    Join Date
    May 2002
    Location
    Northern VA
    Posts
    1,353
    how do you tune a turbo?... can you explain? never really understood that..... what are you able tp change... besides. boost
  14. #14
    got JDM milk??? tokyoracer's Avatar
    Join Date
    Jun 2002
    Posts
    991
    so does this mean the the apexi will make more power with a smaller lbs of boost when compared to the greddy kit? since the apexi is ball bearing.. so i am assuming that it'll spool faster than then greddy? is that correct?
    CIVIC 2K EX - D16Y8, CUSCO STRUT BARS - TYPE OS (F/R), CUSCO LOWER ARM BAR (F/R), TANABE SUSTEC PRO SS FULL COILOVER, 99 Si REAR SWAY BAR, JDM SIDE MIRRORS, AEM CAI, SI UNDERBODY SPOILER (F/R), 95 DEL SOL SEATS, 15" Rota C8 Steel Gray w/ Kumho Supra 712 (205/15/50)
  15. #15
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    Fuel and timing maps. Of course, you would need a way to alter those maps. In the case above, they used an AFC to tune the fuel curve.
    Whether it would make more power per pound of boost would depend on the thermal efficiency of the turbo, and how well the setup is tuned. The IHI bb turbo is about the same size as the TD04H in the GReddy kit, so I would wager their thermal efficiencies are pretty similar. Yes, with two similar turbos, the ball bearing one would spool slightly faster.
    peace an' luv-
  16. #16
    Spec5
    Join Date
    May 2002
    Location
    Northern VA
    Posts
    1,353
    air fuel controller = AFC rite?
  17. #17
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    A'PEXi's acronym actually stands for "Air Flow Converter", since it modifies the MAP sensor signal in order to get the ECM to add or take away fuel, but yes, an AFC does control fuel, and yes, this is a run-on sentence.
    peace an' luv-
  18. #17
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
