A couple VERY serious questions.....
Old 11-28-2002, 02:51 PM
Spike
JDM whore
Spike's Avatar
Default A couple VERY serious questions.....
I have 2 questions which I need real answers for.....SOON!
1) My right front wheels' lug bolt is stripped about 1/3 of the way. The nut won't tighten on there. Is there some way to replace that cheaply and easily? Is it ok to drive with only 3 nuts tightened?
2) My car revs from about 800-2800 when I first start it until about 5 min of driving. After that, its fine. Occasionaly, I will do it on the road, but if I rev it up to 4k or more it will act normal and rev about 800 rpms. Do I need a new fuel pump or something? How much will it cost and where do I get it done?
Thanks!
Spike
Old 11-28-2002, 02:57 PM
Max Power
Buff Member
Max Power's Avatar
1) it's safe to drive with 3 lugs. replacing the lug shouldnt be more than a hundred bucks from a mechanic shop
2) i dont get ur question?
Old 11-28-2002, 03:01 PM
crucial Si
Banned
crucial Si's Avatar
its like $20 to replace a stud at any tire place...ive been driving on 3 lugs for 7 months...no problem here
Old 11-28-2002, 03:07 PM
Spike
JDM whore
Spike's Avatar
Default SCORE!
1) Hey thanks. I'll wait till after Xmas when I can get $100. I'll just keep checking the tightness occasionaly.
My 2nd Q was: My car revs up and down from 800 rpms to 25 rpms when I first start after its been sitting. After about 5 min, it stops. Whats wrong?
Thanks again!
Spike
Old 11-28-2002, 03:17 PM
crucial Si
Banned
crucial Si's Avatar
its only about $20..not $100...$100 would get you 2 new brembo rotors...not just the stud
Old 11-28-2002, 03:21 PM
WideBodyEK
Stage 3 Modified
WideBodyEK's Avatar
your second question kinda sounds like your fast idle is loose,..its located under your throttle body,...dont quote me on it being your fast idle though
Old 11-28-2002, 04:55 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
It's that or a vaccum leak...
Old 11-29-2002, 04:56 AM
Jkan2001
S2000 Pilot
Jkan2001's Avatar
you just need to get a new stud tapped in....if it's on the front it should only be about 30-40 bucks at pep boys or firestone.
Old 11-29-2002, 05:14 AM
Spike
JDM whore
Spike's Avatar
Default Thanks for the help
Thanks everyone. I got what I needed. I'll tomorrow and get a new stud and get the idle checked out.
Spike
Old 11-30-2002, 01:22 PM
tokyoracer
got JDM milk???
tokyoracer's Avatar
Default Re: A couple VERY serious questions.....
i've found the lug nuts to be around $6-7 at a local shop. it's really easy to replace. u just need some silicon spray, rubber mallet or hammer (to pound out the old ones), impact wrench (but not necessary,.. just makes it easier) and new bolts. i've done it several times... fairly simple.
