Shifter problem
i have a dc short shifter, and for some reason when i shift it seems to catch alittle going into gear, it just seems to pause alittle and then it goes right in. is there a reason for that? did i install it alittle wrong or something. 2nd gear has always seemed to catch alittle since ive owed the car, when i installed the short shifter, it helped me shift faster but now catches alittle on all gears.
Any suggestions?
X-Motoring
try swappin ur stock shifter bushings out for some polyurethane ones. they like 15 bukks max and do wonders.
late
That is what i would do. make sure the linkage is all tight
the F is a secret :shhh:
| Throwback S/N Crew | Team F.U.K. | HAN Day Crew | Snowboarding Crew | Cycling Crew | Cooking Crew | Lost Crew | Enough with the Crews |
Long way from home
Is it hitting your exhaust heat shield? Mine was. When I stuck my head out the door and shifted, I could hear the banging. I just took it off.
do you guys know how to stop the shifter from getting hot?
try some heat wrap around the exhaust next to the shifter.
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
