Car won't start after cam install! HELP!!
Old 11-21-2002, 09:59 PM
SiClone
X-Moder8er
SiClone's Avatar
Default Car won't start after cam install! HELP!!
Today I swapped in some Skunk2 Stage 1 cams and cam gears into my 99 Si. I followed all the directions that I found at c-speedracing.com. Their instructions did not include taking off the distributor, which is different from what I've read elsewhere. Everything seems correct as far as TDC and all. Since I had to re-check everything like 3 times, the little distributor knob that the intake cam attaches to was turned a few times. Maybe this is the problem, but I don't know. I also did a valve adjustment. The engine just cranks and does not want to turn over at all. Even the cranking sound is different than before. It's a little more high pitched.
Any help or input would be greatly appreciated.
Thanks.
Old 11-21-2002, 10:17 PM
Nelson
Administrator
Nelson's Avatar
Check timing, maybe your ignition coil... your spark plug wires in correct order... don't crank too much, or you might flood the motor?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 11-22-2002, 02:11 AM
SpeedRacerEX-R
SpeedRacerEX-R's Avatar
When engine is at TDC is your rotor pointing to #1?
Old 11-22-2002, 05:55 PM
SiClone
X-Moder8er
SiClone's Avatar
Yep, it was the crankshaft. I didn't have it lined up at TDC. Once I did that and re-adjusted the valves, the car started up. Now I just have to wait for my VAFC to get here so I can go get everything dyno tuned...:naughty:
Thanks guys!! :thumbup:
Old 11-22-2002, 09:10 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
Where are you going to get it tuned? I seem to remember you being in MN, that's why I ask... Elite, or John Haley, or somewhere else?
Old 11-22-2002, 09:55 PM
Smurf
Dancing Banana Driver
Smurf's Avatar
im installing mine soon.
