Results 1 to 15 of 15
Thread: quick question about stuck caliper.
  1. #1
    im about to go out and buy a new caliper...b/c its sticking and it wont release the pad off the rotor...this IS what i need to fix the problem correct?
  2. #2
    ëast cøast > madlow's Avatar
    Join Date
    Jul 2001
    Location
    new hampshire
    Posts
    2,091
    yeah sounds like the piston in your caliper is frozen. If you can get it off, spray a little 10w-40 and it should free it up.
    AIM: decaldood
    Decaldood.com
    Specializing in automotive decals!
  3. #3
    i tried a couple days ago...i greased it up and everything...still no luck. crystalized my rotor AGAIN
    so go for the caliper?
  4. #4
    のんびり~(´ε`) inspyral's Avatar
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    You might be able to rebuild it, but you might as well get a new caliper if it's not too pricey.
    peace an' luv-
  5. #5
    a new caliper is rebuilt...i gotta exchange the broken one. its somewhere along the lines of $34...i have a discount at the store so cheaper than that.
  6. #6
    Join Date
    Sep 2000
    Location
    San Jo, Cali
    Posts
    2,314
    Do that. I was referring to doing it yourself with a rebuild kit(new seals, etc), but for $34 save yourself the trouble.
    peace an' luv-
  7. #7
    aight cool...thanks..
  8. #8
    Administrator Nelson's Avatar
    Join Date
    Jul 2002
    Location
    NY
    Posts
    42,277
    If this were later, I'd just give you my caliper (given that it fits) because I won't be needing it...
    Alpin weiß ///M3
    EG Ferio - SOLD
    FG Ferio
    www.NelsonLee.net
  9. #9
    how long?
  10. #10
    It's my first day. Fujiwara Takumi's Avatar
    Join Date
    Nov 2001
    Location
    Grafton, WI.
    Posts
    13,635
    caliper rebuilds never go well if you dont know what youre doing, and usually they are like $8 cheaper than a professionally rebuilt one.
    oh yeah, and wd40 is not a valid way to fix a problem...
    www.isellmiataparts.com - World Champion Miata Parts Sales.
  11. #11
    true....
    i used lynthem(sp?) grease...didnt do shiit.
  12. #12
    Join Date
    Nov 2001
    Location
    Grafton, WI.
    Posts
    13,635
    true....
    Lithium, thats not pentrating though, its just grease.
    frankly if iw as going to rebuild a caliper it wouldnt be a quick job, this is something your life depends on. i dont fakirone with brakes.
  13. #13
    god damnit...i just took apart my caliper and blah blah blah..and the fawker gave me a different caliper.. dumbass part runners...i should of known not to trust parts people. shiit, i didnt even bother looking at it until i had the old one off. btw..this one is for an accord..
  14. #14
    Spec5
    Join Date
    May 2002
    Location
    Northern VA
    Posts
    1,353
    its probably frozen cuz the piston is all rusted and eventually built up enough friction on the seals that it wouldn't move... my rear one was frozen... and then I took the rubber boot off and sprayed it with PB blaster and did my best to dissolve the rust. I cleaned it for the most part but its a long term temporary fix. last time I did it was 2 years ago... and then it froze again...
    just replace it if its the front one... this was my rear disc and the cheapest I can find one is $137
    '06 Whitewater Pearl Mazdaspeed6 --> current!
    '02 Blackout SE-R Spec V --> 1/04-8/06
    '93 Torino Red Civic 4dr --> 9/99-1/04
  15. #15
    whoa $137...i just got a whole new front L brake for $48..and that is everything including the brakepad...
    ok this might sound kind gay but it had a new pad in it...should i use it, its only on that one side, and when my front R goes bad ill just change them out...or is that bad?
  16. #15
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
