ASAP!! Tranny fluid
Old 11-19-2002, 05:52 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Default ASAP!! Tranny fluid
How many quarts of tranny fluid for a D16Y8?
Old 11-19-2002, 05:56 AM
b00gers
b00gers's Avatar
buy 3. if you are planning to drain, fill, redrain, fill. then 6.
i THINK they need 2.9.
madlow
madlow's Avatar
until it poors out the fill hole. I think it's about 2.5.. dont forget you can use 10w30 too.
Old 11-19-2002, 05:58 AM
westcoaststyle
Only as a temporary fix.... it's for my friend, I didn't remember how many to get. I always use Honda OEM manual tranny fluid.
Why drain/fill/drain/fill?
Also, I know the process so all you whores out there don't have to tell me how to do it. :chuckles:
Just needed quantity.
Bumnah
So OG it hurts.
Bumnah's Avatar
i'd only use Honda MTF, and it's about 2.2 quarts. have the car level when putting in tranny fluid. once it start coming out of the fill hole. let it finish draining, and close it up.
easy to do.
Project EVA - The Track Package
Project EVA
Old 11-19-2002, 06:02 AM
madlow
madlow's Avatar
1. locate fill plug
2. remove plug
3. locate drain plug
4. remove drain plug
5. wait for fluid to drain
6. screw drain plug back in
7. fill w/ transmition fluid until it leaks out fill hole
8. once the transmition fluid is drained then screw fill plug back in
Old 11-19-2002, 06:07 AM
westcoaststyle
1. locate fill plug
2. remove plug
DAM YOU!!
Well, at least someone actually read the post this time.. :chuckles:
Old 11-19-2002, 06:11 AM
madlow
madlow's Avatar
oh yeah.. Honda always recommends that you remove the negative battery terminal before working on your car. :fawk:
Old 11-19-2002, 06:16 AM
westcoaststyle
really? I was just going to drop the motor to do it... it's easier that way right?
Shame on you! :nono: You're a mod FCOL!
Old 11-19-2002, 08:26 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
http://www.c-speedracing.com/howto/t...ransfluid.html
