1st gen B16A1 into 93 Del Sol Si
JDM all day
I am trying to find out how hard it would be to install the 1st gen B16a1 into a 93-95 Del Sol Si(SOHC VTEC). I know the plugs will be different so what will I have to do. I know I have to get the HAsport hydro to cable conversion, that will be no problem. I also already have an OBD1 ECU, so that's not a problem either. I really need information on the mounts and wiring from the 1st gen B16A1 into my 2nd gen body. Will the factory mounts link up? I heard I have to use 2nd gen injectors, is that true? Sport Compact Car magazine did this swap but I don't have that issue for a reference. All replies will be appreciated.
Well, to start off, you'll need obd1 sensors, injectors, and distributors....The mount should line up and you'll need the hydro to cable conversion for the transmission...Since you got the ecu already, then you got that cover....If i'm not wrong, with the cable trans you won't have the mount from the end(side) of the trans to the body, but all the other mount will bolt up except for the a/c mount( need 94-95 del sol vtec a/c mount)...It should be just as easy as swaping in the obd1 swap after you change out the sensor and injectors..Good luck on the projects and please add more info if anyone has something that I miss or correct me if i made a mistake on any point...
Steve
P.S. If it was me, I would sell the cable trans and save up for a hydro b-series trans...With the money that you make off the cable trans and w/o having to buy the conversion kit you can almost have enough for a b-series and it'll be much easier in my opinions...
Steve
wooooo woooooooooo
If I'm not mistaken, you will be able to use the engine harness off the D16, and once you get new injectors, everything else should button up fine. The only thing that will be an issue will be your speedometer. CRX's had gear driven... Our's use sensors... You may be able to swap that in, but I've never done it, so don't quote me... I'd call up HASport about the swap. They could give you the low down on the mounts and wiring. With the ecu from the old b16's, you'll have to do some rewiring, or get a converting harness...
