got JDM milk???
what do you think?
what do you guys think about this lower tie bar. would this be better than my neuspeed lower tie bar? cuz i've heard good things about cusco.. like that they are beefy... and plus the price is worth it... what do you guys think?
http://www.optauto.com/webstore/prod...k=yes&dept=929
CIVIC 2K EX - D16Y8, CUSCO STRUT BARS - TYPE OS (F/R), CUSCO LOWER ARM BAR (F/R), TANABE SUSTEC PRO SS FULL COILOVER, 99 Si REAR SWAY BAR, JDM SIDE MIRRORS, AEM CAI, SI UNDERBODY SPOILER (F/R), 95 DEL SOL SEATS, 15" Rota C8 Steel Gray w/ Kumho Supra 712 (205/15/50)
If you've already got a Neuspeed tie bar stick with that. The difference will be unoticable. They're both non adjustable which means they are both good tie bars.
got JDM milk???
actually, the neuspeed lower tie are adjustable at the end link. u have to adjust them during the installation.
oh, I was unaware of that.
got JDM milk???
yeah... it's kinda hard to see it from the pic... but from all the install i've downloaded they all said to adjusted.
i figure since they are $87 each for front and back.. i was wondering what are the benefits of putting on in the front? any ideas guys?
Still here... sorta...
PM me about that brace. I can get it cheaper from Options. I'll get you a price tomorrow if you send me your zip.
sancho on the sizzide!
Cusco is always BEEFY
got JDM milk???
yup... BEEFY is good...
for the back, its not worth replacing your neuspeed....you probably won't even notice a different. For the front, its a different story.
のんびり~(´ε`)
Um, you guys realize that's a FRONT lower tie bar, right? Yes, the Neuspeed REAR lower tie bar is adjustable, but their front lower tie bar(which I have) is one-piece billet alu and is non-adjustable.
のんびり~(´ε`)
got JDM milk???
that was one of the questions i had.. cuz the front and rear had the same pic. so i am guess they are the same???
のんびり~(´ε`)
I think everyone(including Neuspeed) is just using generic pics to represent both the front and rear bars, while the pics actually show the same bar, just in black and polished. So people think one is the front bar and one is the rear bar, while in reality, they're both the same bar(rear), just in different colors.
As for the Cusco front bar, it looks pretty good, and relatively reasonably priced. You used to be able to get non-adjustable Z Speed lower front bars for $50-60. Those were some good, low-cost bars. I suspect the Cusco bar is tubular steel or aluminum like the Z Speed bar, which accounts for the price difference between it and the billet Neuspeed bar.
got JDM milk???
chris... in ur opinion... what would u think will be a better bar? neuspeed being billet or the maybe tubular steel cusco? and what is the benefit of the front lower bar?
のんびり~(´ε`)
Billet is stronger, but heavier. Tubular is decently strong, lighter, and costs less. The Neuspeed front lower tie bar retails for about $200(I got mine for $115). I would not pay full price for the Neuspeed bar. The Cusco bar should be fine.
のんびり~(´ε`)
The front lower tie bar performs the same functon as the rear one. It ties the subframe together to limit flexing of the chassis.
got JDM milk???
is the front harder to install? compared to the back?
のんびり~(´ε`)
Nope, same process. Remove LCA bolts, position bar, reallign LCA's if necessary, reinstall bolts.
got JDM milk???
thanks.
how low does it hang? will it get ripped off when lowered??
got JDM milk???
that's a good question. it's very hard to tell. my friend said it hangs really low. but i don't know cuz it may vary from application to application. i'll be dropping by a shop today to check those out... then i'll see how low it sits.
のんびり~(´ε`)
Mine hangs about .5-.75" lower than the lowest point on my oilpan, and I've never scraped it on anything. I'm sitting at about a 2" drop on 205/50/15's in the front. You may have clearance issues if you're lower than I am. My cousin has about a 2.5-3" drop on his 5th gen with 205/40/17's and he took his Z Speed bar off because he kept scraping and hitting things with it.
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
