gsr swap (motor mount ?)
Hi, im doing B18C1 swap on 97 civic i want to know what mounts from gsr motor i can use. I know that rear transmition mount has to be from si, what about the driver side motor mount and other transmition mount, can i use those or i need si mounts. Thanks
it's my D in a B
the integra mounts are what you need for driver's side upper, A/C mount and lower transmission mount. I believe you can re-use your stock upper transmission mount.
:edit: here. Everything is the same except the rear bracket.
will the integra mounts work for the del sol too?
according to this picture i can use rear mount from gsr OBD 2 motor that i got and i dont need a si rear motor mount. Can i use the rear motor mount from a gsr obd 2 motor? Thanks
it's my D in a B
If you have a 92-95 civic or a del sol (any year) you use the rear bracket from any 94-01 integra.
If you have a 96-00 civic, you use the rear bracket from a 99-00 Si.
:edit: Nevermind, I just saw that your car is a 97. You need the Si rear bracket. That picture is for a 92-95 civic. Everything else is the same except the rear bracket.
it's my D in a B
no shit? I thought that the a/c mount, lower tranny mount, t-belt mount & upper tranny mount were interchangable between EG & EK... the rear bracket being the only difference.
