Question about J&S safeguard and oil coolers
Old 05-31-2007, 07:36 PM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
Default Question about J&S safeguard and oil coolers
Like the title says, has anybody used the J&S safeguard system??? And for the oil coolers, For those who are running them, What kit are you using and are you using the perma cool thermostat with the system. Im trying to get my ducks in a row for the build up of my GSR motor for my hatch and trying to get some insight. Thanks
Old 06-01-2007, 05:33 AM
Running925
Your Powder Coater
Running925's Avatar
I highly doubt you will "need" and oil cooler. If you do end up going this route, be sure to go with a somewhat small shortest possible lines and what not because this cooler will drop your overall oil pressure when it's running.
As far as your question about the thermostat with the system. Your definatly going to want one so that its not constantly at a low pressure.
Old 06-01-2007, 04:58 PM
Snoopy
been there done that
Snoopy's Avatar
im using the stock b18c1 oil cooler
Old 06-01-2007, 06:31 PM
HatchVX
HatchVX's Avatar
with the stock GSR oil cooler can you still use a sandwich style adaptor for oil feed/pressure?
Old 06-01-2007, 06:35 PM
as far as i know you can. never heard otherwise
Old 06-01-2007, 08:30 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Yes, they should work together.
If you are interested in an oil cooler, I have an OEM GSR one lying around with a brand new O-ring. All you would need is the coolant hoses and 94-95 water pipe.
Old 06-01-2007, 10:10 PM
HatchVX
HatchVX's Avatar
I have the stock one on my block i was just wondering about the Aftermarket one.
