Where to get some bolts (to replace rusted ones)
Well my Civic is starting to show it's age. A quick tuneup revealed several rusty bolts under the hood and I was wondering where can I get replacement bolts? The bolts that are rusty seem to be all one standard size, the same as the bolts holding on the fuel filter. It's a 1999 civic. Can I just go into NAPA and ask for replacement bolts or what?
been there done that
while i would agree to this on most parts, but they're just bolts. as long as they're the same strength and size as the bolts being replaced i see no problems with getting them from a hardware store.
I think on metric machine bolts some have a number on top for the strength so if it says 10 go with a new 10. If you get stainless steel bolts make shure you don't brake them off the next time you pull them off SS kills drills.
v-card member alpha
Shows how much I know
On a semi-related note, anyone know wtf the yellow-ish/green-ish tinted bolts are made of?
edit: Almost forgot, I've replaced several bolts on mine. In the past I went to ace (I think), most recently went to carquest. So far, no probs.
Once after reattaching my neg. battery cable I realized the bolt was stripped (thanks Honda for cutting V notch in some bolts to make them go into painted threads easier)and so I got it in good as I could and drove to carquest. I didn't want to remove it in case they didn't have the right replacement, for fear the jacked bolt wouldn't take a 2nd tightening, all I told them was it was metric and fit a number 10 socket and they got me the right one. (purchased 2 diff. types just to be safe)
Some might be thinking, "but that bolt is the same as several others in the engine bay, why not use one of those to get a match or better yet, replace it w/ one of several relatively unimportant bolts?" I didnt realize this at the time h: plus was in a hurry
