Need Help Fast!!!
Old 06-29-2006, 09:38 AM
NewCivicFSU
NewCivicFSU's Avatar
Default Need Help Fast!!!
I have a 1992 Civic Lx, replaced radiator, fans work, thermostat is new, and no fluid is leeking. Why did it heat up on me? Randomly, then just go bac to normal.
Old 06-29-2006, 09:42 AM
pissdoffB
Little Miss Dee
pissdoffB's Avatar
flush your coolant system?
Old 06-29-2006, 10:04 AM
NewCivicFSU
Default yes
did that to
Old 06-29-2006, 10:50 AM
Chefboiali
scrotal surge
Chefboiali's Avatar
Were you having overheating problems before you replaced the radiator?
Old 06-29-2006, 11:03 AM
NewCivicFSU
Default yes
yes
Old 06-29-2006, 11:07 AM
b20hatchy
EM1 Crew member #74
b20hatchy's Avatar
Air in your system.
Old 06-29-2006, 11:24 AM
Chefboiali
scrotal surge
Chefboiali's Avatar
Originally Posted by b20hatchy
Air in your system.
Sounds like it to me. If you're not THAT savvy, I'd take it to a radiator shop, and have them look at it. $20 to save you a headache. Just watch them do it. Cooling system can be weird. There are a lot of scenarios that can make your car Heat up bad, then level off.
Old 06-29-2006, 11:29 AM
Rock~1
Rock~1's Avatar
had the same problem. there was air in the system just run the car in your driveway and leave the radiator cap off. after a while you should see the level in the radiator has gone down so pour more antifreeze in. keep doing that till the level stops dropping. shouldnt take more than half an hour if you dont know what your doing.
Old 06-30-2006, 04:18 PM
mishqua
mishqua's Avatar
I new a guy that had the same problem he installed a new radator,new hose's and put in a new thermastat that was faulty. It just wouldn't open up hardly at all.
