omg... engine gone! what 2 do now?
I blew my D16Y8 engine... one of my valves dropped and that was it. I don't know if I should rebuild the engine im wondering if all I need is pistons and valves, ARP head studs and that be it?
Should I get a used d16y8? would that be an easy engine to find?
what would be a cheap and simple swap to perform? I dont have money or time, so im pretty screwed...
if I could I'd do a GSR swap, but thats expensive. how much would a d16y8 run and where can i find one a good one?
i can't seem to find any trusty honda engine sites online that even offere b-16's or d16y8s.
ne help will be appreciated
Originally Posted by Running925
take it apart & figure out what broke first..
go from there
go from there
yeah I'd like to to just go to the shop and see what's needed to be done and see if their statement is exaggerated so they can put in a new engine and get more money from me.
SuMaDiNaC
there is a guy here in onatrio,canada (hamilton area) selling a 1999 b18b with everything axels linkage harnes compleate swap for 1500.00cnd 120km on the engine i can get u his number if u like and u can talk to him who much he whould charge u for shippin adn all that shit
oke here its what it says
Mint 1999 b18b1 Integra motor complete with tranny,srater,alternatior,ps pump,axles,ecu,wireharness, header,new timing belt and water pump,perfect for civic swap,$1500 obo 136,000 km. $1,500cnd 613-229-9533. turn_06@yahoo.com
On permanent hiatus
I would have them show you before doing anything.
If you have the budget, a swap with a manual conversion would be a good idea. Otherwise, rebuild it.
Alright I would just get another motor, drop that in and have your car to drive around in. THEN take apart the other motor, and build that for how ever much spray your using. A simple build just needs headstuds,pistons,rods. You shouldnt need to mess with the head unless your wanting to rev past the stock redline.
Originally Posted by Buyimports2
Dude, if you are worried about money, get a b18b. More power than a D-series and like half the cost of a gs-r engine.
A guy at the shop thinks the Zex stage 2 camshaft was responsible by causing too much stress on the engine with it's lift and the valves were tapping the pistons. I guess the Zex stage 2 cam cause the valves to tap and it's not just the noise from the added lift n duration but the results of it.
