auto to stick?
auto to stick?
heres the deal i decided to keep my hatch so i wanna convert it to 5 spd so if anyone knows any links or what i need and how to do it it would be appreciated thanks in advanced
Rotorphile.
Not so simple, you need to find someone that actually wants an auto Civic first. The chassis is good, but the conversion takes a lot of time and a few dollars.
Originally Posted by JoePoonani
5spd tranny
ECU
shifter and linkage
pedal set
clutch and flywheel
clutch MC and slave cylinder with hardline
Anything I miss?
ECU
shifter and linkage
pedal set
clutch and flywheel
Anything I miss?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
i appreciate it now if i wanna do a swap do i still need to buy a special mount or not. am colombian im in ct too far! so i guess i gotta do some shopping this week and some work. thanks again
HIDs teh hotness!
you i went through this same shit, post on here for help on converting an my old auto to 5speed and i got the same asshole replies......but ya know what i converted mine and LOVED it.....you're going to need the pedals, master cylinder with/resevoir, slave cylinder, tranny w/ flywheel and clutch, shifter, shift linkage, either bracket off 5 speed civic console or the console itelf (cause of the bracket that holds boot), shift boot, and ur gonna have to chip ur ecu to tell it ur a 5 speed now......i'm sure there a couple other things but thats all i can think of right now, its alot of work but worth it in the long run, just go to a junkyard and u can get most of the parts u need, tis what i did hope this helps....also the top tranny mount will have to be fabricated a lil, the auto mount is pointed up a lil and the manual is straight so u have to cut it and reweld it or what not
