Car Running Rich, How to fix?
Old 03-26-2006, 04:31 PM
buzlink
buzlink's Avatar
Default Car Running Rich, How to fix?
I think that my car may be running rich.
If I drive it for 30 minutes or more in warmer weather, the idle and engine firing starts to act funny. If you turn the car off and come back to within a short period the car seems as it doesn't want to run in lower gearing and at idle. Also driving at 20MPH in 1st and 2nd the car misfires really badly. Also in 5th at highway speeds the car will misfire slightly if traveling up a hill. The car never has up and down idling. The ideling acts as the car doesn’t want to run, or the engine is not firing as normal.
I have pitch-black exhaust residue on my tailpipe and back bumper.
How does one diagnose a car running rich? What causes the car to run rich?
What needs fixing? Do the above symptoms sound like another problem I should look into?
Thanks
Old 03-26-2006, 08:25 PM
Kabooki
Kabooki's Avatar
check timing, replace dist. cap,rotor. sparkplugs/wires (basic tune up) and check air filter would be a good starting point
Old 03-26-2006, 09:53 PM
ReVenGe
ReVenGe's Avatar
ok.... i may sound crazy..... but i never realy payed attention.... but isnt there like a little nipple that you turn on the intake to change that? or is that the idle?
Old 03-27-2006, 06:32 AM
buzlink
buzlink's Avatar
My dad is thinking its the MAP or O2 sensor.
I think that is the idle adjustment screw. Not sure.
Old 03-27-2006, 06:35 AM
Running925
Your Powder Coater
Running925's Avatar
new spark plugs!
ngk only!
Old 03-27-2006, 07:55 AM
buzlink
buzlink's Avatar
Originally Posted by Running925
new spark plugs!
ngk only!
Has had new spark plugs as of recent.
Old 03-27-2006, 08:14 AM
bambbrose
bambbrose's Avatar
what brand? did the misfiring occur before or after changing spark plugs?
Old 03-27-2006, 09:31 AM
Wharbone
Wharbone's Avatar
I'd check your timing and also see if your timing belt jumped a tooth.
When you replaced your spark plugs, did you do a full tune up (plugs, wires, cap, and rotor)?
Old 03-27-2006, 10:17 AM
buzlink
buzlink's Avatar
After changing spark plugs I did not have any problems. It has been a few months since the spark plugs were replaced. NGK spark plugs.
I don't think it’s the timing. The car runs normal and starts up fine with small runs around town. The car only acts up after driving for 30mins or more.
No I did not do all at the same time. But all items have been replaced within the past year.
Thanks
Old 03-27-2006, 10:22 AM
F22B Prelude
Rachel Bilson
F22B Prelude's Avatar
Check Engine Light or No?
